after updating to Android 7.0, I constantly get a popup dialogue box that says "attention, data roaming is on. international roaming charges may apply. etc". I'm not taking about the notification that appears from the pull down menu on the status bar. this is a dialogue box that appears over the screen anywhere I am in the system. it happened at least 6 times today and only has two responses you can tap on. either you choose settings or cancel and neither dismiss it permanently. anyone else experiencing this?
