I seem to notice a red tint around the edges on white screens. Also it will have a red tint if you tilt the screen. Has anyone else experienced this?
Did you order from Samsung? Why can't t we return to the carrier? I'm going to go to Verizon later today and try I'm just hesitant because I don't want to get any crap from themSomething to note called Samsung for a replacement and they only do returns you have to send the phone back and wait for your money this sucks
That's what I figured. It's a software issue so why go thru the hassle to return the phone when the one you get might have it too and can simply be a software issue. No biggie.
If the whole screen is red, the software might fix the issue. However, I am not sure it can be fixed with software update if only the edges are red. Also, someone on reddit has a very noticeable red tint on one side of the edge only instead of both sides.
