Every time I play a message then put the phone to my ear, when the screen goes black the message pauses. What would make this happen? Do I have a setting not set right?
Mine started doing that since the Nougat update on my S6 Edge. Haven't been able to figure anything out yet. Other than the fact that it's super annoying.
Found some more info out in this thread.
https://community.verizonwireless.com/thread/914794?start=90&tstart=0
Seems like turning off certain Samsung Pay options is a temporary fix. Use Favorite Cards and/or Manage Favorite Cards.
Hopefully Verizon and Samsung figure something out.
I have no favorite cards and all the "Use Favorite Cards" selections off and so far Voicemail is working
Same here. Turned off favorite cards and it worked. How bizarre.Turned off the favorite card on the home screen option in Samsung Pay and that fixed it. Thank you!
This worked for meFor those that attempt to disable a specific setting and it fails, just disable ALL favorite card settings and its fixed. For my S8+ I had to disable ALL samsung favorite card settings for it to finally work.
