A
The phone will not factory reset unless he enabled the 15 wrong password setting. Try calling Samsung and provide proof of ownership. They may be able to help you.Sorry but there is no way around this, it is meant to be completely secure. Put in bad passwords and factory reset the phone. It's ok to write down the number and store it safely.
I think the intent was to suggest a possible way to bypass factory-reset protection, not to bypass device encryption.What, you think they have a back door?
Google can't help with it. Frp is also on the device.I think the intent was to suggest a possible way to bypass factory-reset protection, not to bypass device encryption.
Can't you disable FRP as long as you can get into your associated Google account, even if you can't remember the device password?Google can't help with it. Frp is also on the device.
If they remember that sure. If not then nope.Can't you disable FRP as long as you can get into your associated Google account, even if you can't remember the device password?
OP didn't say anything about forgetting their Google password. But even if they did, it can be reset in various ways.If they remember that sure. If not then nope.
And I never said they forgot did I? . I just said no one can help with getting by it just like the Samsung one.OP didn't say anything about forgetting their Google password. But even if they did, it can be reset in various ways.
Encrypted phone after restart with pin and now i have foegotten my pin. Can anyone help?
