Has anyone else noticed a direct correlation between average or medium cellular signal from mobile data and the battery being used a lot quicker? I can almost watch my battery drain if I do not have a full five bars of cellular signal
Cell signal is the highest cause of battery drain ruling out any rogue app. Don't go by the bars, use something like LTE discovery to view the actual db range. Once you get into the -105 and above you'll start to see significant drain. The antennas work harder to maintain signal which draws more power.Has anyone else noticed a direct correlation between average or medium cellular signal from mobile data and the battery being used a lot quicker? I can almost watch my battery drain if I do not have a full five bars of cellular signal
