Keep scrren on short cut
mawallace
Active member
Aug 22, 2014
26
I would like my Samsung s8 screen to stay on while on charge so i can follow cricket scores while the match is ongoing.
How so i do this and is there a short cut button or app i can use
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
The longest timeout is about 30 minutes, so just touch the screen once every 30 minutes. (And make sure you keep the brightness down or you risk screen burn-in.)
Of course you're probably running on a charger (you should be, so you don't damage the battery by draining it too low), and you can set the phone to not turn the screen off during charging.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,587
6,173
113
In developer option you have the option leave screen on while charging.
Go to about phone software build number tap it 7 times to activate it.
drkrleitch
