Lynnie056
Got the Supcase Unicorn Beetle Pro and I love it. It has a plastic cover and rugged plastic and rubber back that snap together. Adds weight and feels very secure. No issues with touch screen. Very happy with this case.
Has anyone ever used one of the Zizo cases? I heard they were highly rated with great drop protection (I think it was tested at 12 feet).
Wondering how much extra bulk they add.
Too bad the look and color choices are so unattractive.
I've been looking at other cases but it seems like the majority of what's on Amazon now are clear cases and I'm not interested in those.
https://www.amazon.com/dp/B07B2QVJC9/?coliid=I1KSI1HMK60U8Y&colid=OAS64OQ5OVHM&psc=0&ref_=lv_ov_lig_dp_it
That Lifeproof one looks great!I have two cases, first is the Caseology Skyfall clear back case with a shiny purple edge that looks phenomenal with the lilac purple phone, and my second case came tonight, the Lifeproof Next case with the beach pebble edge and clear back that is drop proof, snow proof and dirt and sand proof. Both show off the lilac purple color really nicely.
So torn though between style and protection because I like the look and feel of the Caseology, but I know the Lifeproof will protect this super expensive phone better. So I'll just keep that one on even though it makes the phone a bit wider. It's still just as thin though and dust and dirt won't get into the ports.
The Lifeproof case is really nice and if you are looking for something a bit wider this is perfect. Ports are nicely covered and buttons are easy to push. Very thin profile too. The clear back shows off the phone color. Worth the price I think as nothing could be more durable than this thing.That Lifeproof one looks great!
I'm actually looking for a case that adds some width to the device.
Not sure about spending $80 for a case though...
Thank you for all the info!The Lifeproof case is really nice and if you are looking for something a bit wider this is perfect. Ports are nicely covered and buttons are easy to push. Very thin profile too. The clear back shows off the phone color. Worth the price I think as nothing could be more durable than this thing.
No, I don't have a wireless charger and I use a popsocket so probably won't get one, but I am told it will work fine.Thank you for all the info!
Have you tried wireless charging with it yet?
Anyone use Bodyguardz cases? I ordered the Ace Fly case & their curved tempered glass screen guard since it was 30% off - still pricey at 24$ for the case. Any feedback would be appreciated.
So - if you spot any sweet looking cases for the upcoming S9 and S9+, post them up here (with links please!).
It's a $900 phone. I don't think $24 is pricey
I agree with you 100% and pay much more(if you've read any of my posts especially the reviews on Whitestone you'd see that) but you have many here who think even 10$ is too much to pay... I'm trying to cater to all and not offend anyone.
Turns out my son's wireless charger is old and is not like the new ones that work with a phone case something I couldn't try it. But I have read that they do work with the Lifeproof case.Thank you for all the info!
