amyf27
The warranty replacement you're asking about? A few weeks back, it completely froze then decided it had moisture in the port and wouldn't charge - there was no moisture. I could turn the phone off then back on and it would charge for a very short time, then that moisture alert came back on, and no more charging. I went to factory reset it and though it did factory reset, it literrally rebooted about 20 to 22 times before it finalized.For what?
I haven't had those issues with the replacement Note 8.
