hasasimo
Re: Is the S9+ better?
Reviewers have already said they noticed no difference between the S9 and S9+ hands on. The extra RAM is primarily for use of the telephoto lens. I have a Note8 and it seemed S-Pen functionality and the telephoto lens were the only uses for the extra RAM. There are Grace UI improvements that make it marginally snappier than the S8.
The only reasons to go for the Plus are wanting the bigger screen while not caring about one-handed use, and/or if you really plan to use the telephoto lens extensively. And that's ok... there's no right or wrong decision.
The extra RAM will lead to an overall much more fluid user experience (just compare the Galaxy S8 to the Note 8). Battery life is also bind to be better on the +
