I'd like to turn off the notifications that the app power monitor has killed or put to sleep a process that I get when I open my phone. I like that Android is doing this, but I don't need to hear about it all the time. So I don't want to turn this off, but I also don't want to get a notification about it when I open my phone.
The only setting that I found for this is under the 3-dot screen "Advanced" on the "Battery" screen, which appears to be a notification setting for the "App Power Monitor". However, I can't tell if this is just turning off the notification, or the whole function from the way that the description of this setting is worded. I'm a little nervous that if I turn this notification off using this switch, that I'll also be turning off the functionality.
Does anyone out there know if this switch just turns off the notification, or if it turns off the app power monitor?
Thanks!
Thanks!
