I've been using the full screen gestures instead of the navigation bar for the past couple days. One thing I can't figure out is how to enable the split screen view when using gestures? I'd assume you would just hold up on the recent gesture but that doesn't work. I might have to go back to the standard nav bar if I can't get split screen to work. That would be really poor design if there was no way to enable split screen with the gestures. If anyone knows how to do this, let me known
