Stock Android (and I assume Samsung didn't change it) is to just lock the screen. When you try to unlock it with your fingerprint, you should be given a keypad for your PIN. (There are different timers for screen blanking and locking, so actually lock the screen to try it. And write the PIN down and stick it in a sock drawer. You'd be surprised how many "I forgot my PIN" posts we see.)
