Yeah no problem. If you were to have an empty box and fill it with clothes. It would be super easy to fill the box at first. It would gradually get harder to cram more clothes into it as you go.
Same concept for the battery cells. As you do this, the cells degrade and what was once holding 4.2v at full charge, is now holding 3.2v, and so on. Now when your phone is at 100% of 3.2v, it is going to drain quicker than 100% of 4.2v.
Manufacturers can set what "100%" charge is. If they want to prolong overall battery longevity over having the longer lasting charge, they will set 100% at a lower voltage. And vice versa. Mostly, manufactures set it to a higher voltage as customers don't care how long their phone's battery will last, only that they can make it through a day of use.
Charging Lithium-Ion Batteries – Battery University
