paintdrinkingpete
I've tried steps 1-12. Android System use still at 50%. I 'force stopped' just about everything Google. Android System use is now at 6%! I'm not sure how long 'force stopping' all these apps. will last. But right now I'm happy with the 6% usage!
Android system at 50% *can* be normal, depending on the context. In order to evaluate whether it's normal or not, at the very lease we'd need to know (1) the rate of discharge of the battery %/hr, (2) what other apps are showing up in the battery log during the same period, (3) screen time during that period, and (4) network conditions, such as wifi, 3G, 4G, strong signal, weak signal, etc.
gNow isn't really that big a battery hog. For Android System issues, read this thread: http://forums.androidcentral.com/sa...android-system-eating-your-battery-check.html
Honestly, it can really depend on your environment and how you use it. I spend all day at work in an internal office with pretty crappy cell reception and absolutely no GPS line-of-sight, and I find that when I leave GNow enabled my battery drains a good 20-30% during my work day than it does when I leave it turned off...so that's what I do, leave it turned off.
