When a battery hits 90%, is it actually at 90% or is it 99% or even 95%? Because I was lightly using my phone for a span of about 20 minutes and it dropped to 90% and I was wondering if it actually 90% exactly. Thoughts?
The stock battery shows in increments of 10% and shows something like thisWhen a battery hits 90%, is it actually at 90% or is it 99% or even 95%? Because I was lightly using my phone for a span of about 20 minutes and it dropped to 90% and I was wondering if it actually 90% exactly. Thoughts?
You could download a battery-meter widget that shows values down to single percents (e.g., 93%), then see what the stock battery meter says at that point.
Do you know of any widgets that have single digit increments for our A2?
The Circle Battery Widget show battery percentage on 1% increments. It's available on the Android Market for free
I took my phone off the charger the second it said one hundred. I used it for literally five minutes (I checked the times) and I didn't even use the internet, it went down to 90%. Explanation?
That's because of how the battery displays capacity....it will show 100% capacity once the charges exceeds 95%, so if you were to unplug it as soon as it showed 100% it really wasn't fully charged and would only need to drop to 94% in order to then show 90% capacity. This is another instance where the circle battery widget comes in handy, it shows capacity in 1% increments so you can see exactly when you battery reaches full charge.I took my phone off the charger the second it said one hundred. I used it for literally five minutes (I checked the times) and I didn't even use the internet, it went down to 90%. Explanation?
I am clearly no expert, but most everything I've read says you should leave it charging for 2 to 3 hours after it says that. Personally, I don't care what my phone says at that point; it's the bottom of the scale I am concerned with, and (so far) I haven't gotten a reading below 40% on my busiest day!
This device by far has the best battery life I've seen on an Android Smartphone I'm am simply Astonished!
I currently have 7 different Android devices all Newish and had 10 others in 2011 this one is way underrated.
