where can i get one? i need one more for my car charger. i tried to search in ebay and the other sites but the picture shows a micro usb cable. which is different.
If you have a car charger from a G2 or any similiar they all work on the Amaze. The amaze added the bottom part of the plug to add stability otherwise it is exactly the same and works also with the computer . Save yourself some money buy a 6 dollar one on the street. It only has to match the g2 or g2x. T-mobile will never tell you this because the new connector will make them tons of money.
I called HTC and asked for the name/part number so I could order an additional cable. They ended up mailing me one for free. Item# 73H00389-11M. Description: Accessory Cable, Black, Micro USB (5/12 Pin) Cable W/ CE_htclabel, Black LLDPE, FOXLINK, 6691-1047-0283
Interesting, could you post a picture of the connector so we can see? Is it a typical Micro USB connector or the HTC varient that comes with the phone?
After I got my Amaze a few days ago, I tried a regular Micro-USB cable to plug into my computer. It charges the phone, but it does not engage the data transfer function and windows says that this device is unrecognizable. If I plug it in with the HTC cable, everything is good.
Also, I tried to plug this regular Micro-USB cable into one of the USB to wall socket adapters for the iPhone but it does nothing, no charging. I would be interested in hearing others' experiences.
FYI, HTC Tech support told me he wouldn't recommend using cables not designed for the phone, meaning "typical Micro-USB connectors" even though it would work. I asked why? He basically told me the phone shipped with the cable designed for the phone. I can send you pics of both cables, but it is the same one that comes with the phone, unless you just want to look at it anyway. Also this a copy of the packing slip.
Well, I feel pretty darn confident concurring with you that all cables are about the same (four wires), aside from construction quality differences. The AmazonBasics cable I bought is sturdy, with nice solid connectors (which I think is doubly important for such a tiny, fragile thing as Micro-USB).
But I had to read up on USB (as much as Wikipedia has) to understand the note about shorting out D- and D+ for a device to recognize the connection as a charging port, vice data port. Those data ports are supposedly used for negotiation of power consumption with a host hub; shorting, I have to guess, tells a device like the phone, "Oh, it's not a data port, it's a charger/charging port that can give me the whole hog 1000mA I crave. It's a juice trough, all mine mine mine...."
I'm not sure how reliable the information on the phone is (T-mobile's My Device app's Battery information section, or the Android info at Settings | About Phone | Battery), but when I plug the phone into my Thinkpad's USB port, both state "Charging (USB)."
I then plugged it in to a Duracell car/home combo charger, same thing, "Charging (USB)." Same with a Belkin combo power strip/dual-USB charger. I plugged it in to an Apple 5V 1000mA charger (the cute little square white one, with the green dot) which should also provide 1A, but the phone still said "Charging (USB)." Then plugged it into the supplied HTC charger, and the status indicated "Charging (AC)." It doesn't seem to be charging any faster.... Just for farts and giggles, I tried the "cheap" car charger that Costco's wireless vendor gave me ... it also shows "Charging (AC)."[1]
Short of finding super-thin leads that I could do a short test with my multitester, I remembered that the iPod has a diagnostic boot menu ... sure enough the Power menu has USBDP and USBDN tests ... I connected to an Apple charger and found iirc roughly 1700mV on the USBDP and 2300mV ON USBDN. I recall reading somewhere that Apple does this for their devices to identify their charger, or something. I put the iPod on the HTC charger ... 0mV and 0mV on USBDP and USBDN
I can't say how many watts are being sucked from any of the chargers. I'm looking for a widget that might disclose that ... if the phone even knows has a sensor for its charging wattage.
BTW, not *all* chargers are alike, iPad chargers are 10W chargers, i.e. 5V @ 2000mA. If you plug an iPad into a conventional Apple 1000mA charger, and leave it on, I understand it will tell you "Not charging." You have to turn the thing off and ... leave it for a few hours. Some confusion about this
[1] For years I'd liked that Nokia billed their car chargers, and premium varieties of AC chargers, as "rapid charge" chargers, and they certainly seemed to charge my phones quicker. Handy indeed for either application, in which the time that a phone would be "plugged in" could be assumed to be briefer.
I have Thunderbolt and Rezound, and both have a sensor to read battery charging amps. You can use a widget like "battery monitor widget" to see and log battery drain or charge. You can compare different charger/cable combos to see what you get. I've found at least on both of my Rezounds, that the cable itself didn't matter in terms of charging or data connection.
Does the Amaze really take 3 hours to charge?? Or is that on a lower wattage cable?
