My husband decided to root his Optimus T Blk. He rooted the phone successfully but he got as I have began to see it called on the forums "uninstall greedy" or "uninstall happy" Some where along that uninstalling spree he deleted what I am assuming is the LGhome.apk due the issues that we are having. Here is my thread from another site that I had no responses to, maybe you guys may be able to help.
Ok here we go.
Thanks in advance for reading this and maybe being able to help me.
My husband decided to get adventurous with his Optimus T Black and try to root it because he was reading about all the extra things you can do with it, on it, app wise etc. . . I am usually the one that does all these kind of things NOT him. I thought he was joking, I was wrong. He made it thru the root process it looks like he was able to customize the font and options on it and then all of a sudden "force close" pop ups starting popping up non stop so he manually shut the phone down by pulling the battery. When he tried to turn it back on and will not go passed the "Android" screen.
I have read many threads and just can't seem to figure out what it is, I thought it was bricked and then it came back on but everything was enlarged, kind of zoomed in it seemed, it was mainly unresponsive black background and icon tray at the top the only thing that appeared but nothing functions. Then I tested it and it goes into emergency mode just fine without a problem and comes out of it. The power key+vol. down does nothing for me, no download menu comes up it just boots up and then stops at the "Android" screen again.
The laptop is not recognizing the phone when it is plugged into it and the LG Update tool isn't recognizing it either and there is no way to try to restore the firmware thru that tool since it won't recognize it.
Any suggestions on how I might be able to solve this issue? For now I will continue to creep and crawl thru Google search results and forum posts to see if I can find anything that relates. But I am pulling my hair out
Thanks again in advance for the help.
Next was an update:
UPDATE:
MORE ISSUES THAT ARE OCCURING THAT MAY HELP IN FIXING OPTIMUS T
The phone powered on to the home screen (with the sliders on it) but it comes up with the icon tray at the top and the screen is black with no background or icons. Here is the WEIRD part: phone is sending and receiving texts without a problem. You have to recieve the text and then it becomes visible (when it first comes in) you can type, respond and do everything you would normally do on the phone and then send it. It then returns to the inbox of messages but if you hit home or back out of that you are back to the black screen of nothingness. Now while typing this update his phone recieved a phone call from a friend and it came up as it normally would, I slid the slider and answered the phone call, once it was over it went to recent calls briefly and then to the screen of nothingness again.
WHAT THE "F" (Pardon the "f") could be causing this? Did he erase an important file possibly? He rooted using the z4root way, I don't know much about it becuase I have never used it or do I want to risk rooting my G2 until I fully understand what the heck I am doing so that I don't end up like him and his phone. I asked him if he backed the phone up, he said "I don't know", I asked him what process he took in rooting it and he said "z4root" I asked him what files he deleted off of the phone and he said "There was instructions and color coded symbols with the files I could delete, green meant safe to delete, red was not to be deleted, I erased the 'green means go' files and nothing else" So he definitely did something wrong to cause this issue but no idea what. . . Thanks again for reading the post and attempting to lend me some tech advice on the issue
BTW: His phone has Android 2.2 on it and yes it does have third party apps but it started this after the "thought to be successful root"
HERE ARE SOME PICS:
https://mail.google.com/mail/?ui=2&ik=546dff08f2&view=att&th=12e694ac8cdde496&a ttid=0.1&disp=inline&realattid=1361939324241707008-1&zw
https://mail.google.com/mail/?ui=2&ik=546dff08f2&view=att&th=12e694d7ed690816&a ttid=0.1&disp=thd&realattid=1361939400041168896-1&zw
https://mail.google.com/mail/?ui=2&ik=546dff08f2&view=att&th=12e694d7f1fee306&a ttid=0.1&disp=thd&realattid=1361939363600007168-1&zw
and then the last update I posted on it. . .
Okay, I have been searching for HOURS on end now, since about 8 am this morning and finally found something that seems like it may suit the issues. Does anyone or has anyone ever acccidently removed there "home app"? Reading these issues match right up with the ones we seem to be having. . . any input out there at all for me? Even just a suggestion in the right way would be more than highly appreciated.
Now tonight/ early morning/ evening, depending on where you are in the world.
When you plug it into the computer the driver reinstalled (LG updater will not update it, says it is current on firmware) and the phone functions completely normal EXCEPT when you try to use the home key/menu key/ search key/ back key then the black screen appears with the system tray at the top and that is it.
I HAVE NO IDEA, I AM ABOUT TO TAKE THE DEFEAT. :'( HERE ARE A FEW MORE PICS FROM WHEN IT WAS HOOKED UP BY USB TO THE LAPTOP. Also all the restore modes/emergency etc seem to work fine. . . the factory reset didn't seem to do anything tho even tho I saw the little box with the android buddy. Still same results as before. we downloaded Access point and I just simply added it to the phone in the download section but nothing, I am not sure how to use ADB and didn't want to chance anything else.
IF YOU CAN HELP PLEASE PLEASE DO!
https://mail.google.com/mail/?ui=2&...1&disp=thd&realattid=1361960209755406336-1&zw
https://mail.google.com/mail/?ui=2&...2&disp=thd&realattid=1361960209755406336-2&zw
https://mail.google.com/mail/?ui=2&...3&disp=thd&realattid=1361960209755406336-3&zw
https://mail.google.com/mail/?ui=2&...4&disp=thd&realattid=1361960209755406336-4&zw
https://mail.google.com/mail/?ui=2&...5&disp=thd&realattid=1361960209755406336-5&zw
https://mail.google.com/mail/?ui=2&...6&disp=thd&realattid=1361960209755406336-6&zw
https://mail.google.com/mail/?ui=2&...1&disp=thd&realattid=1361960943815229440-1&zw
https://mail.google.com/mail/?ui=2&...1&disp=thd&realattid=1361960922577371136-1&zw
https://mail.google.com/mail/?ui=2&...1&disp=thd&realattid=1361960975755902976-1&zw
https://mail.google.com/mail/?ui=2&...1&disp=thd&realattid=1361961000441479168-1&zw
https://mail.google.com/mail/?ui=2&...1&disp=thd&realattid=1361960868447780864-1&zw
Ok here we go.
Next was an update:
UPDATE:
HERE ARE SOME PICS:
