I have a Samsung Galaxy S4 running 4.4.2. The phone is basically stock (I'm using a different launcher). I recently bought a Plantronics Voyager Legend bluetooth. At first it worked fine. Occasionally, when I made a call using the Plantronics all calls after that call were muted: I could not hear anything and the person on the other end could not hear me. Even when I disconnected bluetooth and used the phone directly everything was muted. I had to reboot the phone or do a reset of the Plantronics to get the sound back. The problem continued to get worse until now after the first call I make using the Plantronics all calls are muted and I have to reboot. Strangely, I can still hear music over the Plantronics under these conditions. The Plantronics appears to pair normally and remain paired.
This is what I did to troubleshoot:
1. I talked with Plantronics, updated the software and eventually they sent me a replacement Legend, which of course made no difference.
2. I've checked the volume sets on the phone and Plantronics and they are set to medium high.
3. I have force stopped all apps which also made no difference.
4. Uninstalled Utter and Secure Settings which I had used with voice control and suspected that it might be causing a problem - didn't make a difference.
5. Disconnected wi-fi.
I think that the file or process or whatever that mutes the phone while making calls with a headset must have been corrupted but I don't know enough about that to tell. My next move will be to do a complete factory re-set of the phone and wipe out everything loaded on the phone, unless someone out there can figure out another way.
Thanks for any help. JH
