★ ☆ | ROM | NuSenseROM | ICS Sense 3.6 | BEATS AUDIO | XLoud | Beta | ☆ ★
Re: ★ ☆ | ROM | NuSenseROM | ICS Sense 3.6 | BEATS AUDIO | XLoud | Beta | ☆ ★
Sounds like it worked. Glad we could help.
So far changing the Scene and the lock screen to AOSP seems to have done the trick.
not sure why, but just got a replacement thunderbolt. im trying to flash 7.6 but its freezing up in the middle of flashing. i am able to flash to a back up of 6.4 but cant flash 7.6. i also had this issue trying to do a clean install of 6.4 last nite
at least it appears to be frozen. says its installing system files, but the progress bar isnt moving
disregard. apparently i was just being impatient
Flashing the newest version now. I will be back later to report how awesome it is. What is the old saying? Give a mouse a cookie? Think it should be give a Bolt a ROM instead.
Ignore.
Sent from my ASUS Transformer Pad TF700T using Android Central Forums
Awesome, looking to hear good news. I saw a couple of days ago, Santod changed his post to version 10.x but apologized he didn't have time to load and and wanted to be sure what he was loading was in good condition. That is great development there.
I'm looking to hear back how the new version runs. For the meantime, I cannot part from this working combo radio (posted for v6.4), will 10.x need same combo radio or a different one?
Santod posted regarding 10.x and radios: "I've been testing this latest build all day on the working Bolt and I can't find any issues. I even went as far as to try several different radios with it and fired up wifi and bluetooth and made calls and texts on any radio I tried, without issue. My preference is still the ICS radios, especially with the newly added Ril, but there don't seem to be any showstoppers in my brief testings with the others FWIW. I kinda have one or two small changes I may or may not make before uploading, nothing crucial or critical and I may just skip it for now since all seems so solid as is..."
10.8 is now live
Arrrrrrgh now I need to dl it. Oh well, I can sleep when I am dead.
EDIT: Getting it now, sleep during dl then flash flash flash, Have to say I am loving it(7.6) so far. But my inner geek wants to be up to date so here we go 10
Let me ask you guys, if I were to flash 10.8 (if I could and had the time now) would this be an acceptable way:
1) make nandroid of current (6.4)
2) wipe all 3, 3 times each in recovery
3) flash 10.8
4) restore data only in recovery. This way all my settings, apps etc will be available after rom loads.
5) let rom load and settle
I'm assuming #4 can be done easily without having problems later on, when doing this from the same roms right?
I tried it for the first time when I went from bamf forever 1.10 over to NuSense 6.4, and I think because the one was GB and the other ICS with both having different Sense versions, it caused some spaghetti.. So I wiped all 3 again and for 3 times and simply flashed 6.4 nice and clean and manually went in and configured all my settings. I'm hoping that by going to the same rom all will transition smoothly when in recovery >advanced>restore data only.
Any other tips/methods/suggestions appreciated.
Sent from my ADR6400L using Android Central Forums
3) flash 10.8
Santod is very thorough and detailed, you can read his suggested install procedure HERE. He frequently updates the first 3 posts of his Nusense thread.
the only way ive ever flashed any rom was through rom manager and letting it clear data/cache and dalvik cache. nevr had an issue. thats not to mean i couldnt ever have one, but no problems yet
but thats only because i dont have 4ext
Viper I am a noob at 4ext but it is worth the $3 for it. I love it as much as CWM.
In recovery, has anyone restored data only from the advanced section
This is what i meant to see if i could do from 6.4 to 10.8
Have not done so, sorry
It is pretty neat as let's say you go from one rom to the next, you can restore the data only, from recovery, so that when you load your newly flashed rom, all your icons will be in place on home screens, and all apps (I think only 3rd party) will be loaded too, no need to TiBu. All will be loaded when the rom loads.
In short, make a nandroid of current rom that will be replaced, you clear all 3, flash the new rom, then while still in recovery, in advanced, restore data > from any nandroid you have saved.
UPDATE: I noticed that after flashing your new rom, let it fully load, skip any account settings (not needed), go back into recovery, then select Backup&Restore>Advanced Restore> then choose the nandroid that you want to copy the data from........ and walla! when all is done, your new rom will load, with all your data from the previous rom, all accounts, your background/wallpaper, widgets and their placements, apps and thier placements on homescreens, alarm clocks etc! :cool:
HMM seem to be having some problems with the newest version, have to check out Santod's thread in the other area. I should have done the restore thingy maybe?
owo Emmanuel
