★ ☆ | ROM | NuSenseROM | ICS Sense 3.6 | BEATS AUDIO | XLoud | Beta | ☆ ★
Re: ★ ☆ | ROM | NuSenseROM | ICS Sense 3.6 | BEATS AUDIO | XLoud | Beta | ☆ ★
I love this Rom more and more with every update!
Sent from my ADR6400L using Tapatalk 2
I would stay at 6.4.... just saying... I had a bunch of issues with 7.2. but try and let meknow how it works for you ;)
So I ran with 7.2 and had issues with some apps not starting and being unable to get the phone to reboot...back on 6.4 now and everything is working.
I love ICS...my 4G download speeds have doubled over what I got with GB. BTW...I'm using the combo .19 radio with leaked ICS LTE radio
Haven't had a single issue with 7.2 other than the Twitter issue. Even that isn't a big deal because I can still use Twitter, just can't update it
Well I take that back. Not sure if its Rom related, but I just got a call, and I was getting feedback. It went away if I held phone away from ear
Yep... just flash in recovery.
Can someone please explain in simpleton terms how to do this? I've just flashed NuSense and have no ringtones. I downloaded the linked ringtone fix, but don't exactly know how to flash it? I don't want to screw something up.
Since you already have NuSense loaded up, just reboot into recovery, click on install zip from sd, the pick choose zip, then scroll down to the ringtone fix zip file and click on it. After it does it's thing, go back to the main menu and click reboot phone now.
Edit: Before you do all of the above, make sure you transfer the file to the root of your sd (not in a folder).
Thank you. I just wanted to be sure that applying a new zip in recovery like that, the phone would understand it was just updating and not screw up something.
No worries. You shouldn't have any problems.
You can do it from a folder, I keep all my ROM zip files in folders. The only thing you have to do from root of SD card is flashing a radio.
Definitely more laggy than Liquid's rom, but if I can get bluetooth working reliably again I'll learn to live with it. I do like that my list view for apps and a dialer that you can insert pauses for speed dial is here. Now to get everything set the way I want it. I'll try out the .19 radio today. If that doesn't seem to work well, I guess I'll learn to flash a radio tonight.
Of course, you're absolutely right, and I should have made it clearer. Thanks!
a few questions and issues im having.
1. my mic doesnt work during phone calls unless i turn speaker phone on, tried everything i can see but nothing helps. any ideas?
2. i have haptic feedback turned off in my messaging but when i text its still vibrating.... and it seems to cause the screen to lag. would like to keep the original messenger but if i need to go with a go messenger i will.
3. is there a way to make the volume louder when i have headphones plugged in? tried dolby, and beats, they are all real quite. tried dl some eq and volume boosters but they dont do ish.
4.the original radios seem to work, but i feel like it should be quicker . i live in CT, does anyone in the area have a great working radio? can i check what im running for speed?
sorry for the newb questions my first root and rom. oh ya running beta 7.6 with 4ext touch
Just trying to help BUT... set up acct here NUSENSE ROM INFECTED WEBSITE!!! because alot more people are way more active with this ROM and will answer you right away. it will only take you 3 mins to set up an acct.
seth
After loading the ROM everything is all good. Then I will start to get "unfortunately, wallpaper has stopped" and I will have to go to settings or quick settings to see the background. I restored my backup and then re-installed from scratch and it still comes back. Is there something I can do to fix this? Everything else is working perfectly and I don't want to go back to stock.
any suggestions would be greatly appreciated.
Thanks in advance.
I'll sometimes get "lookout is not responding" so I hit wait and it goes away for a while. Combo radio is golden! Tethering without the annoyance of signal going in/out like I had in past, loving it!
Sent from my ADR6400L using Android Central Forums
7.2, so the new one. I will download 6.4 and try that.
Thanks in advance.
Read the OP on InfectedROm.com about this issue. It is in post #3 I think. Something is messed up with the homescreen launcher. When you make a folder in the launcher it will crash the wallpaper on the lockscreen. Some of us couldn't even change any icons out or it would crash. If you swipe down on the notification bar and open up setting or something it will give you the wallpaper error that you can just hit OK. Then go back in to personalize and change the scene to something different basically making it default the homescreen launcher shortcuts. Problem solved, Santod is working on a fix.
Changing the lock screen to AOSP also seems to fix this issue.
Awesome!!! Thanks @stratejaket and @falcon2058
Hixson21
