1.85 OTA rolling out now
I need some help. Got the download accomplished, but got the endless spinning wheel and no re-starts. So while I am told "System Update Complete" I still have 1.73 showing.
So, it seems i need to delete the download and try again. Opened it in Astro but dont know exactly which files to delete.
If anybody knows, please let me know. Thanks in advance.
You opened the zip file with your file manager. Don't do that.
Back out of the zip to the directory above.
Then Delete the entire zip.
Sent from my HOX
After reading this on AC, I went to Settings -> AT&T software update -> check for updates. Less than 5 minutes later, and one restart (which it did automatically) I have the 1.85. Pretty painless.
Immediately I got notification of a voicemail received 8 hours ago, which has happened to me in the past with Sprint as well as in the last month with AT&T.
I did have the issue of the mobile network turning itself off, so I hope this resolves it.
I haven't noticed anything too different after updating. Multitasking isn't any better but I'm sure they'll eventually fix that.
I would like to see them fix that stutter when you first open the app drawer though. It looks so silly how hard it stutters lol.
Sent from my HTC One X using Tapatalk 2
The update was quick and easy for me. I wasn't experiencing any wifi or reception dropout prior to the update, so I can't tell the rest of you who are that its fixed, what I can say is there is no difference than how it was working before the update. No more smoother nor does the multitasking work any different. And it's been said by HTC the multitasking is working as it should.
Sent from my HTC One X using Android Central Forums
Updated mine today using my home wifi. No problems at all, went off without a hitch and notice no increase nor decrease in performance as of yet. I never really had any wifi issues anyway.
Went smooth. Only issue is that speaker volume is diminished. Ringtones, music, and media loudness is significantly lessened at full volume.
I still cannot get the update. Tried wifi, hooking up to computer, changed date several times. I click on check for updates and nothing happens.
Any ideas?
...maybe try a reboot, and see what happens.
Any ideas?
Thanks. Tried that several times too and nothing.
Manually change the date to 2 or 3 days ahead and then re-try. I had the same problem and it worked after I did that. The whole thing took 5 min.
Same here. 6/8 was my magic number.
thanks. I changed it 2 days, 5 days, 10 days, 20 days, and a month ahead. All after reboots and still no luck.
Mine is not available yet :'( On another note could someone help me figure out how to search on this phone? I'm puzzled without the search button. thx
Use the google search bar. It can search your phone
I just bought a white one, with the Otterbox case.
AT&T opened the box in front of me (they never use to do this; the box use to be opened prior), and the device already had the latest update on it. Hmm, interesting...
Marlene
