1.85 OTA rolling out now
I have gotten the UPDATE popup twice...and both times selecting it has done NOTHING. Sigh. All I want is my Slacker Radio to play flawlessly while navigating and even with an update I fear it won't.
I still have the problem with WiFi thinking it's still connected to the AP even though I've left the area. Very annoying. I had hopes that this will get fixed with this update.
Anybody still seeing this issue with 1.85 too?
Does the AT&T version have Auto Disconnect in wifi advanced settings?
If so, have you tried turning it on?
Sent from my HOX
Stuck at verifying package. I have tried to update several times. Longest stuck at this was over an hour. Deleted update and download again. Same thing. I've never had this much issue with updates before
Sent from my ASUS Transformer Pad TF300T using Android Central Forums
Twice I received msg that download was "corrupted". Deleted file.It let me re-download, but nothing happening - no reboots, swirlies, anything to suggest action. Software still shows 1.73.Third time, download did not show up, and it will not let me download again. Will try again tomorrow.
Has anybody noticed any improvement in signal drop issues? I swapped out a new sim and a new phone the other day, hoping it would fix signal drop issues but it does not appear to have done so. The hardware is shipped with the new software.
The signal drop issue I am referring to is when the 4g and reception bars still show connectivity, but calls/texts are not received, data is not working, and in settings, the mobile network actually shows "disconnected" or "turning on."
this happened to me as well.
i made sure to do a restart by holding the power button after clearing the download and also made sure that wifi was disabled before restart. worked like a charm the second time
I also get the unfortunately, HtcDm has stopped. if this keeps it up i will cashout on this badboy and get the galaxy s3 the one thing i hate is an update to fix crap and your phone can't pull it down due to the system itself.....
Whats up with this crap I have tried for two days and get this. One more day and this bad boy will be on eBay any else getting this.
Sent from my HTC One X using Tapatalk 2
Guess what the update just ran. I got a message saying sorry it was unable to connect to the servers and about a couple of mins it said checking manually and boom it was there looks like I'm gonna keep it
Ok yesterday I was pushing update to no avail. I finally got it to update. Not sure why it finally worked as I had tried all of the same steps as before. I put the phone on wifi, unclicked network time, rolled the date to the next day plus a few minutes. Voila update appeared and downloaded. Took about 8 minutes after the download completed.
For those that have Root and don't want to lose it. Do this download Voodoo OTA Rootkeeper. Launch app and save root access. Now do the OTA upgrade. Once installed open Voodoo and get root access back. I have tested and verified that root access is kept and that all apps work.
just chill, it will update, took me 3 tries over 2 days, but it insdtalled with zero input from me other than installing new drivers and plugging in to my puter at work, it went flawlessly and told me the update was successfull
Based on what I read in the AC forums, I advanced date (I ended up in September because I did not notice that date wheels are day/month/year) downloaded, nothing, deleted, advanced date a bit, and got the download to work the second time. EDITORIAL: the average consumer does not read AC, and could be frustrated by the process. It really should not take a village to do a simple OTA software update. AT&T and/ or HTC need to work on the delivery mechanism. Having said that, glad to finally have the fix for this instrument, which I bought for its superior form factor and screen. There were initial problems with the GNex, and I understand the folks on Big Red just got the version 4.04 to fix those problems. I am sure the SGIII will have some initial problems as well. It is the nature of bringing out new devices to have some glitches. However, it is just important to think about the delivery of the fix as well as the fix itself.
AT&T sends the update in batches instead of all at once, if they did it all at one time it would overload the servers. They have always and will always do this. Most updates take 2+ weeks to reach all phones depending on how many phones are scheduled to be updated. It is not just HTC phones it is all phones on AT&T's network and all the carriers do a similar type of update process. It will come be patient. The selection for update schedules could be by date of purchase or by serial number esin or account number who knows.
Sent from my HTC One X using Android Central Forums
Well if it was by purchasing date then I should have been one of the first to receive update. I just worked for me last night
apache dawn
