AldousSnow
- Jun 7, 2010
- 401
- 4
- 0
cr12's Apps on the phone
theres my app list.
tia
im not using atk its just on there, also disabled all background updates. i have the battery monitor because so much heat is coming off my phone and i wanted to monitor temp.
4 hours.. 2 hours.. 1 hour.... whats the frequency?
Well.... I'm planning on getting 24 hours today...
Not using ATK.
I am using GPS and Wi-fi.
I sync Gmail.
7% battery loss in 2 hours 15 minutes... not bad.
Ok. Well it looks like you solved my issue. I know you stated to ignore the battery level, but I've been using my phone a lot since my last report. I am down to 40% with moderate to heavy use and been on almost 5hrs. I am confident I could get another 3hrs hours out of it, at least. Maybe a little less. I think this I can deal with. I know on Tuesday I didn't get 5hrs with minimal use. I'll keep going for a little longer to see how much more I can drain the battery. Again Thanks for all your help and recommendations.
1. who are you talking to?
2. what do you think fixed your "problem"? what was the solution?
No you can turn off each individual one. I think this saves the battery big time...
Go To Settings>Accounts & Sync
Scroll down and you can see individual programs with the green dot lit up on the right. Click that dot so it goes grey. Like I said, the only ones I leave running for auto sync is Gmail, Twitter and Weather.
Got it. Thanks alot! I was able to get my news and stocks off sync. ?That should help.
