2.3.3 .....blank screen
i have the same problem with my phone... i can call or receive a call but as soon as i use the phone apps, my phone is stuck there, frozen! and the only way to end a call is to remove the battery! i have read the previous post on this page and you're talking about a gingerbred update or something like that... just to let you know, i havn't done any updates on my phone before it start doing that... If i cant find anything on the web to help me with this problem i'll bring it to the store... but im sure they wont be able to fix it anyways
i've done a reset to default a couple of times but it havent change anything... except that i lost all my contact and apps... :p
I have research this problem inside and out. I have loged over 24 nonstop hours trying to fix this darn blank screen, and all I find are hundreds of gingerbread devices having the same blank screen issue. I think it is an issue with 2.3. my tablet wont even go to reboot and will not obey any core system comands. so if you say you havent had anyone complaining about this issue, you didn't look! cause they are every where begging for someone to help them, and nobody has an answer for the blank screen problem. I just baught mine a week ago. this is the same song alot of 2.3 (gingerbread) users are singing.:mad:
kctraci1
