Tweezle
- Dec 22, 2011
- 19
- 0
- 0
Are you rooted? Have you deleted any preinstalled apps?
I *was* rooted, but I unrooted it in anticipation of the update.
I have not seen a conclusive statement on this forum about whether being rooted totally prevents the automatic update. Others have asked the question too.
If you are rooted with Clockworkmod as your recovery, the update won't install automatically. You can either install it manually or flash back to stock, unroot and then let it install automatically.
If you use Wug's toolkit to flash back to stock and unroot, it will wipe your device so make a backup first using Wug's toolkit not CWM.
OK, my friend, you nailed it for me. I have CWMod recovery installed. I was hoping that it would not matter, but I'm just some old guy who doesn't know any better.
I have downloaded the full update image and will do it the manual way. It's probably about the same (or less) amount of work and time as flashing back to stock recovery and then doing the automatic update, then re-rooting it for some" fun" later.
Thanks for the help! That's why I come here.
UPDATE: Flashed it manually. No problems. I'm unlocked, rooted, and up-to-date.
Now to watch for improvements. Then I'll start playing ROM Roulette. Maybe.
