.35 Gingerbread/ICS Kernal
Did anyone else try this on a thrive and have same results as kushkingz did
So as best I can tell, this is the current state of things.
OLD BASEBAND ---ie you did NOT update to the official LG released Gingerbread update
Thrive (506): You can use Jobans .35 kernel (which is not posted online anymore, but can be downloaded from other users) and Aspee patch. With those two you can use any .35/NBB based ROM. Phone/Data work, but wifi does not.
Phoenix (505): You can use Raenye's combined kernel. You can use any .35/NBB based ROM. Everything works.
NEW BASEBAND --ie you updated to the official LG released Gingerbread update.
Thrive: DO NOT try and use the Phoenix (505) kdz. It appears to be causing massive problems. Use the above methods if you want to go to .35/NBB
Phoenix: Once updated, people can switch to a //35/NBB based ROM but cannot get data or wifi.
Does that sound about right?
Good news for you turkeys:
I'm about to upload the stock LG P505 (Phoenix) source to my BitBucket.org repository and begin the patching process.
UPDATE: The official repository for the LGP505 (Phoenix) kernel source + my modifications is on BitBucket.org. If you can't see any files, it's because it's not finished uploading yet. I will be working for about an hour and a half tonight patching the kernel, and you all will be able to track what I'm doing using the aforementioned BitBucket repository link.
savior1974 tried it on his Thrive (506) and said that he couldnt get data or wifi.
Can we confirm this?
I tested on thrive and got 3G voice & wifi working.
(didn't test data, but without the old baseband fix I couldn't get the sim recognized at all)
My happiness meter went from [--] to [-----------------------------] :D
So if we flash this, it will function the same as Jobans? We can flash any rom we want and then just toss the kernel in and everything will work squeaky-clean?
Sure, hopefully. Also, I broke the build completely so I now need to start over from scratch.
Clarification: you'll be able to flash ROMs for the P500, but some may need more than just a kernel.
We have been down that road already there are some ROMs that work great with jobans kernel and others that wet the bed and cry for mommy. One thing is for sure there is no lack of people willing to try out ROM's till we find a really good one.
Also sorry I havent been around much lately and given much help things have gotten crazy around the home front but I hope things will have calmed down soon and I can at least do some beta testing if you get a kernel released.
brucestark2741
