4.2.1 Update Received
Re: 4.2.1
I didn't have any issues with reboots, and little trouble with lag with 4.2 once I cleared the cache, but it does seem to have even less lag now with 4.2.1.
Previous update rollouts tended to be over 2-3 days, so I would expect similar with this (though perhaps quicker since it's such a small file size).
The one known fix is that December was missing in the People app before. It appears they may have refined a few other things while they were at it.
Thanks, I'll keep checking.
Re: 4.2.1
Has anyone noticed if any of the issues they were having previously have been resolved? Reboots, lag, ETC? Just curious.
I never had any of the other "issues" people are reporting so pretty much status quo on my N7. It was such a small update (maybe a bit over 40mb) that I think this was the December people calendar fix and not much if any more.....
Re: 4.2.1
Nothing in New York and I've been trying the clear Google services trick.
Re: 4.2.1
My N7 updated to 4.2.1. It was waiting for me when I switched on WiFi.
Now waiting for my GNexus to update.
I read that this should fix issues with Bluetooth Calander etc.
Re: 4.2.1
Got it in Canada. Notification came in while I was at work.
Re: 4.2.1
Got it this afternoon in Oregon. Scrolling "seems" to be better, but still the occasional jerk.
Re: 4.2.1
... It was such a small update (maybe a bit over 40mb) that I think this was the December people calendar fix and not much if any more.....
The fix for the N4 (December in People) was just a megabyte so this is encouraging....
(edit)
Sorry, Android Police reports it's only about 1MB.
(edit)
Confirmed. 1.1MB.
Re: 4.2.1
I don't have as much lag as before while scrolling through my widgets. Notification shade seems to be working better than before. Seems a bit snappier overall.
Re: 4.2.1
Mine didn't auto pop but when I checked update system in the settings its waiting for me to connect to Wi-Fi. Dumb.
Re: 4.2.1
My notification shade doesn't bounce down and pop all the way closed anymore, which is nice.
Sent from my ADR6400L using Tapatalk 2
Re: 4.2.1
So I got my update but it keeps failing during install. I'm rooted and every time the update starts it kicks over to CWM recovery and stops with a message something like, "do you want to install this untrusted zip file" I say yes but it still fails. I have even tried to manually install the update through CWM but that fails too. My N7 is rooted but otherwise stock, I have not removed any stock apps or flashed roms or kernels so WTF...any rooted N7s having this issue?
Re: 4.2.1
Anyone who didn't have problems with the original 4.2 update having problems with this update? I'd rather skip December then have to factory reset the Nexus7.
Re: 4.2.1
I've had zero problems with 4.2 and 4.2.1. Install went without a hitch, didn't have to factory reset.
Re: 4.2.1
Got it here in the UK. Still yet to apply. Woke up this morning and it was there to install - only got my Nexus 7 yesterday.
Taylor Bag
