4.3 Tomorrow for ATT HTC ONE according to article
Downloading now. 565.7mb. Tricked the date to be the 10th.
Did you have to trick the date because of the 24hr restriction on checking AT&T for updates? I didn't have to change the date and my phone is downloading the update also.
Yes, if you checked for it in the last 24 hours, you have to wait- or change your date forward to start the download.
Downloading in California right now. 565.7MB. Huzzah!
No time trick needed.. I did AT&T software update, it said I couldn't check for 18 hours, and then a minute later I got a popup that said Update Downloading. Go figure.
Holy crap! It is live! Downloading now!!! :)
This is certainly a miracle from ATT and HTC. Good work! :)
Shucks, didn't fix my lowlight camera issue. This is with the camera down on a black desk.
Downloading now here in Central Florida. 565.7 MB, and going pretty slow on my 60Mbps connection.
Still nothing here in Indiana. I changed date to the 10th, but it's been checking for update for the last 15 minutes. I'm over it. - I'll get it, when I get it.
Sent from Xsie's HTC One using AC Forums mobile app
Abidalyy739
