4.3 Update for Sprint Galaxy S3 has Arrived
What state are you in?
The updates aren't rolled out by region.
- - - Updated - - -
Does the update unroot?
Yes.
Actually, that's overly simplified. If you are rooted, but completely stock, with all OEM files and stock recovery, you can apply this update and it will unroot. But if you're running a custom recovery, the update won't work at all. You'll have to wait for someone on XDA to post a pre-rooted zip.
Root users, note that existing root procedures do not appear to work on 4.3. So if you unroot to install it, you may be unrooted for a while.
Any word on the version of Swype included with the 4.3 update?
Also, is this likely to be the last official update?
Sent from my SPH-L710 using Tapatalk
I love the new update! The look and feel is great and visually so much more updated. Loving everything so far and o problems so far, just started playing with it though....
Currently showing 1.5.19.21097 for Swype.
My wife will be getting it on her bone stock S3 one of these days, so I'll get to try it out there. I'll post my impressions after.
What is this Knox issue that I keep reading about over in the XDA forums?!?! Anyone care to briefly explain whats the deal with that, please?
Well downloaded it from XDA... It's alright I guess nothing really exciting to make me go WOW DAMN!...
There seems to be a constant battery drain so far, at least for me. Anyone see notice anything from playing around for a bit?
Has anyone tested the move to SD Card for apps? I did this on my tablet and it just kind of moved them and some I had to reinstall. Anyone know if it TRULY works?
liquidsnake757
