And I'm reading to use 45w charging you need a USB 3.1 gen 2 cable, which maxes out at 3ft. Wtf. This confirmed? I love my 10ft USB cable
Where are you reading that? A quick search on Amazon and I found a type C cable with a 60 Watt rating.
The 50% in 20 minutes is the cool part to me, as someone who has forgotten or been unable to plug the phone in overnight before.
That would only hold true if starting near zero. With sealed batteries, it's especially important to practice good charging habits, meaning trying to keep between 40-80%. So if you start at 40%, you'll only see that super fast speed for maybe a 10% boost and then it'll start to slow down.Yeah, I think this is the biggest advantage. You pick up phone and 20% and realize I am leaving in 20 minutes for a couple of hours, I am screwed. With this you can pop on and get a nice boost to last a few hours.
I'm now waiting to see the flood of complaints of ruined batteries in under a year because of all these 0-100% tests making people think that's actually acceptable long term on a sealed battery.
This is what I have been thinking. One would suspect that doing fast charging all the time over the long term will shorten battery life immensely.
According to Android Authority however, the Samsung charger is a special case, instead of the highest-rate charging of 45W being due to 15V x 3A (which is as per the standard) it actually 10V x 4.5A.I was referring more to the act of going below 40%, and especially under 25%, causing greater wear on the battery, regardless of charging speeds.
Faster charging speeds can shorten battery life too, depending on how it's done. Li-ion phone batteries top out at 4.2-4.3V. Traditional charging was variable voltage up to 5V input and variable amperage. The old rule of thumb was a standard Li-ion battery can safely be charged at 1C during the constant current charging stage. 1C means an input current equal to its capacity. A 4,000mAh battery could accept up to a 4,000mA (4A) charge current.
I've been meaning to do some more research into modern chargers with variable voltages. That 45W charger can run at 15V/3A through the cable to the phone. What I don't know is if that is stepped down in the phone to put 5V and 9A into the battery itself (minus efficiency losses, of course). A 9A current would be just over double the N10+'s 4,300mAh capacity, or just over a 2C charge rate. I've seen some speciality Li-ion batteries rated for up to 5C charge rates, but they are bulkier due to the design changes needed to handle the added stress. I doubt that could be done in a phone and remain as thin as they are. I haven't read anything about using higher than necessary voltages, or how it would affect the battery. Without knowing what's going into the battery itself, I'm hesitant to guess how the 45W would affect the battery compared to the 25W.
I bought a 45W Charger on Amazon and using the cable the Note 10+ came with, the estimated time it gives me for the phone to be fully charged is a few minutes more than if I used the charger that came in the box.
sounds like you need a different cable for the 45w charger then
It looks like it charges faster at lower percentages though. Like the oh crap my phone is dead and I have to leave in 10 minutes range.
That still only tells us what's going into the phone, not what's going into the battery. Even when looking at speciality batteries I know are rated for higher charge speeds on stand alone programmable chargers, they still follow the standard Li-ion charge protocols. Stage one is constant max current and a rise in voltage. During this stage, the charger still keeps it at around 4.2V input and the charging speed comes from the current. At stage two, it saturates at a constant 4.2V and amperage goes down until cutoff. Phone batteries do go just a bit higher to 4.3V, but I've never seen a Li-ion battery get 15V input unless it was a multi-cell pack in series (phones were single cell). This video shows what can happen if you use too high voltage.According to Android Authority however, the Samsung charger is a special case, instead of the highest-rate charging of 45W being due to 15V x 3A (which is as per the standard) it actually 10V x 4.5A.
I just bought myself one of these:
MakerHawk Type-C USB Meter Tester Power Meter USB Multimeter Voltage and Current Tester 0-5.1A 4-30V USB Power Tester Multi-function Tester Display Capacity Voltage Current Detector https://www.amazon.com/dp/B07GQLYMR...ag=hawk-future-20&ascsubtag=UUacUvbUpU6615236
