Mooncatt
Ambassador
- Feb 23, 2011
- 11,114
- 884
- 113
I am sure you can find what you want if you google it.
So in other words, "Go educate yourself?" That's not how it works.
I didn't see a limit on video for 4k
Did you record for a full 10 minutes? It wouldn't give a countdown from 10.
No I didn't try for 10 minutes but no countdown like my note 9 or s9+
Same. Verified and no limit either.
Also, hevc only if you enable it.Does 4k record to the SD card, internal storage or can you choose? Also, is video in the HEVC format?
A few things here. First of all, the Exynos is not necessarily better than the Snapdragon any more. In some ways, it's the other way around. I believe the Snapdragon is seeing better battery life. Secondly, Exynos can't do CDMA, so is not used in the US. Lastly, as far as internal storage, if you intend to do a lot of 4K 60fps recording, I guess you might want to go big on internal storage.I'm just curious, with regards to the Snapdragon vs Exynos chips, if one is better and the other is inferior to the point they have to dump down the phone with the better chip so that they're both on equal grounds or one can do something that the other one can't, why even bother with inferior chips anyway? Why not just use the Exynos chips in all flagship phones and be done with it? Why even bother with inferior chips in flagship phones to begin with? Why not delegate the inferior chips to lower/more budget model phones only? Shouldn't an expensive flagship model phone all have the same chip performance and run on equal grounds to begin with? I feel so cheated to find out that I've been buying flagship model phones that have second rate chips over other phones of the same make and model~!
Also, if it's true that there's no time limit for 4k but the caveat is that you can only use internal storage, would it make sense just to fork up more money for the 512GB version rather than going the cheaper route and getting the 128GB version + a 512GB MicroSD card? So in other words, a SD card, even if you buy a top quality one, doesn't have the same performance as the built in storage? Kind of like a NVME .m2 drive will outperform an external drive regardless the quality of the external drive?
BTW, my S7 was overheating and shutting down just recording 1080p/30fps. I found out that just by disabling motion stabilization cured the overheating and shutting down problem. I'll probably disable it on my s10 just because I like to record long events like MX races and concerts so I'll probably try to set it up to be able to go the long-haul on recording so I'll probably be sticking to 1080p but I'll let it record at home at 4k to see how long it can go and how far I can push it. MX races are usually hot and indoor arena concerts are also usually very warm spaces.
Correct. It's one of the reasons it's not suggested to format them as adoptable storage even if the phone has the ability (though, not the biggest reason). As of right now, there are no micro-SD cards that can write as fast as the phone's internal storage.
That['s going to change soon (possibly in time for the Note 10):
https://bgr.com/2019/02/26/microsd-express-speed-vs-1tb-cards-vs-ssd-fast-microsd-coming-soon/
Ew BGR. I can't click that.
I don't think it matters. As I said, Exynos doesn't seem to be the clear winner any more.Exynos can do CDMA but Qualcomm charges out the a@# for licensing. Maybe if the antitrust trial goes against them we could start seeing the exynos here again.
