5.9.905?
I just updated to 905.
Sent from my DROID BIONIC using Android Central Forums
Looking good so far. Gonna go test it out at E3.
Can someone that has downloaded post the version:
For example, 5.9.905.XT875.Verizon.en.US
or just take a screen shot.....
Thanks!
Does anyone have a link to download the 905 update? My Bionic has some sort of problem and the update function does not work.
I am not interested in a leaked version, I want to have the official version update.
Months ago, I had to restore my stock phone to get updates to function again. I'm not sure if there is any other way to resolve that issue, so you might do a bit of googling to see if there is a better way. good luck.
I previously did a Google to have a fix and then I spoke with Verizon and even the executive offices of Motorola but to now avail. At this point I don't think there is enough "upgrade" to justify factory reset and the reload all software and then adjust all of my custom settings. I may do the factory reset when 4.0 is released.
PS: Once you did the factory reset did the upgrade problem ever reoccur?
Thanks!
Ask and ye shall receive:
FYI, I updated and kept root. I was already rooted with 4ever root. :-)
Reactions: BBSeattle
Hello,
When I click on System Updates it still tells me my phone is up to date but I'm on version 5.9.902. SHOULD it be telling me that or should it be able to find .905 and let me go through the process? Or do I have to wait for them to push it to me?
Thanks!
On 5.9.902 and still waiting here, as well. "Your device is up to date! No update is necessary at this time."
Hello,
Thanks!
DING! DING! DING!
Seriously, yes, you'll have to for it to be pushed out to you. Have patience, young padawan.
The soak test will only last a couple days, based on how that goes it should pushed to everyone next week. It's coming soon, .905 not ICS.
soraplzzzzz
