6.0.1 installation error
Thanks.
Any thoughts on my last post and why I don't seem to be able to go from fastboot to recovery?
My bad. The Android robot with red ! triangle is OK. From there you have to hold Power and press Volume Up until it boots into Recovery mode.
I successfully wiped my cache partition.
The screen reads "Android Recovery" "google/shamu/shamu"
So it should be OK. I'll see in a month if I get the security update.
whenever i try to install the android update on my lg gpad, it says " unfortunately google play services has stopped" not error.
tinni99
