6.0 Marshmallow: Europe (XT1541) roll out
Google music downloads to my internal storage just checked, I use Spotify and downloads go to SD card, Wi-Fi is same as lollipop camera is auto focus working as should, browsing in chrome is working as should or as fast as connection is so far I've not had any major problems
so just Play Music not downloading to SD Card and downloading to internal storage instead (and Google not fixing it)... ok, basically same issue as the 6.0 build distributed last month in Spain.
Yip seems that way I'm sure I read this happened with all updates to 6 or that only people were complaining about Google music not downloading to SD card I've not read anywhere that anyone has been able to download music to SD card maybe a fix in future updates
No info yet however seeing as India and the USA has a thread we should have one too. I will update this when info becomes available.
I got the update today, no problems so far. I'm in Ireland and I've got the XT1541 1gb model (obviously). My carrier is METEOR.
I cannot move my apps from internal to sd card after doing this system update..........
Correct, that is not supported in Marshmallow with the SD card as portable storage, you must format it as adopted (internal) storage to have apps on the SD card.
BTW, this is an Android thing, not a Moto thing... Android will likely never support moving apps to SD when the storage is external/portable ever again.
and hopefully there's no more 8 GB ROM devices !
Hi,
Last week I got my note about the System Upgrade, however I was on the streer with low battery, thought that I will do at work on wifi, so clicked "No, Maybe Later". I was noted that I can do it again from Settings...
However since then System updates tells that "Your device's software is up to date." :(
Is there any idea how I can force it again? Or how much time do I have to wait?
Br, Levi
Hi,
Br, Levi
Hi Levi, welcome to the forums! Just wait a couple of days until your phone is included in the next update batch. No need to worry.
Hi,
Thank you. So It means that dont click"Maybe Later", because this is the only opportunity to install it? So cant postponed even with a few hours? (of course I know we could install the image from PC, however I'd stick with this simple solution because of the installed software as well)
Problem or bug
Hello,
This days that i uptade messenger or any other app it auto deletes its files...
Has anyone got this problem or know the solution??
Re: Problem or bug
Yea i have it as adoptable
well in 5.1.1 apps installed in the SD Card would be installed back to internal memory when updated and you needed to switch them again to the SD Card. It seems you're suffering the same issue in Marshmallow (not a bug) and maybe you just need to manually set them to install in the "adoptable" storage every time they update, if this does not solve your problem then it's your SD Card acting up (or even Marshmallow) and you should try a different card. UHS-I grade and class 10 speed are the specs you're looking for since Motorola Moto G 2015 hardware can't take advantage of faster cards than those.
good luck !
good luck !
Thanks! I will try it
JasonReed
