6.16.215 ics update leak
Got a zoom, sweet!! Pics came out nice.Very easy to get back to .211. Use Matt's DROID RAZR utility 1.81 option #1 and it will do the work for you. Good luck.
Sent from my DROID RAZR using Tapatalk 2
Thanks for the support i appreciate that. I know this isnt part of the thread but the Motorola's get such a bad rap for there camera but the hardware is top notch. The software is what it doesn't do it justice nothing 3rd party apps cant fix the picture quality is there.
Sent from my Droid Razr Maxx using Tapatalk 2
Lol thanks my only concern is im going to have to revert back to .211 once vzw decides to push out the OTA and from what i saw was a 15-20 step process kinda scary. Yeah i know we can do screen shots. I had my Xoom right next to me when i made the post so i figured why not..
It was really easy
I am unable to download. I get a message that says "hoster bandwidth exceeded." I am assuming this is unrelated to something I might be doing wrong? Any suggestions? Thanks so much!
Your gonna have to find a mirror of the download. Its not your fault. Just to many people downloading from the same host.
The 16 steps may seem intimidating, but really they are baby steps. It's like what Anthony said, just follow Matt's utility and you'll be fine.
Thank you for the feedback. I haven't been able to find a mirror, but I will keep looking.
One definite noticeable difference is the much faster connection to LTE. Usually it took almost Minute to connect on .211 and .214. Chrome seems a bit more responsive as well. Just downloaded this morning so haven't got to test battery.
Took the plunge I hope this works well for me like it has for others
Sent from my Xoom using Tapatalk 2
Will I be able to downgrade to 211 with a Mac?
Sent from my DROID RAZR MAXX using Tapatalk 2
How do you download the 6.16.215 if you keep getting the following message: (The user hosting this content is out of bandwidth).
Not with this method, but there could be another way.
Thanks. I'm just gonna install a copy of windows on my mac that way when the OTA update comes out I can revert back to 211. Downgrading isn't hard right?
It may look like a lot of steps, but they're just simplified for the average user. The process itself shouldn't be difficult and if you run into any trouble you could always post back here.
Thank you for your help! I'm officially running. 215!!!! :D
Reactions: apquijano
wobblefix
