Will updating to .215 erase my phone memory (i.e. texts, apps, etc...)
Awesome. Thanks!Nope
Sent from my DROID RAZR using Tapatalk 2
After the Leak is updated will you be able to accept any Mortola updates with out removing the leak?
Thank you
Azle
That should still be back in my directory/files right??
Thanks
Azle
Thank you I understand the proceedure, I was wonwering if the 211 was still in the setup file (not sure of the correct lingo) or if I had to load mentioned steps to get back there. Thank you again. I will go and load it for future references.
Azle
that is a big file right,
Azle loading it for awhile now?
Thanks mate, just ripped it....
