6p on AT&T ?'s Please
Depends on where you live too. Coming from an Galaxy S6 Unlocked SM-G920F on AT&T in NYC the 6P on AT&T is a huge upgrade since it has all the bands. The SM-G920F was a UK version that didn't have all AT&T LTE bands.
I work in a basement and I barley would get service, wouldn't get texts, but now no problem.
I use my Nexus 6P on AT&T in southern California. Depending on where I am I average about 27mb down. Inside the mall and on some freeways I get over 90mbps down.
My previous phone was an unlocked gs6 I got the same speeds but at work at my desk I at lease got edge speeds. With my 6p I get no connection. :(
Yeah. What a difference it makes. HD Voice just started working on my Iphone 6S+ a few months ago and it is awesome! This may be a deal breaker.
Hopefully AT&T will bring it to Android. VoLTE & HD voice for T-Mobile is working fine with the stock 6P.
Att user here as well and I can say this phone has really good antennas in it. I had a note 5 and that struggled to even get 3 bars of service in my house. The 6p seems to always be full in my house. So that's a plus for me.great service, great phone period.
AT&T already offers it on Android phones. ONLY on AT&T branded phones however. Its very unlikely that until HD Voice (VoLTE) will come to third party phones on AT&T until it becomes standard on every phone.
what are you ATT folks using for APN to get LTE? I am in an ATT LTE area I've tried a few found on here with no luck yet
ATT Nextgenphone
default,mms,supl,hipri
In Phoenix, AZ.
But if I've learned anything from the pages and pages of threads on AT&T (and Verizon) LTE, you could set your APN to the same thing and still not get LTE. It's a crazy mess. But - try that and see it how it goes. Make sure you reboot your phone after you change it.
Good luck!
ATT Nextgenphone
In Phoenix, AZ.
Good luck!
Thanks tried it and still a no go, oh well :(
- Sometimes I might get H other times nothing, although I have a strong 4 bars of service
- I've been on with ATT, upgraded my imei # with them, turned off the phone and then removed the sim card, rebooted, etc., etc.
- Spent an hour on the phone with Google Tech Service and got the same old line "we've had no other complaints" :confused:
- Scoured the 6P threads for answers to no avail
- I might return it as during my work week I spend a considerable amount of time well out of the range of WiFi and count on the strength of my ATT LTE service quite heavily
So far so good. Used AT&T with my N6P for all but one day when I tried Google FI. Was not impressed with FI at least not in my area and not at this time. I have had zero issues with AT&T even updating my IMEI went smooth.
Thanks.
Your issue is most likely caused by the SIM linked to a unrecognized IMEI in the AT&T database. Just link your SIM to a know LTE device (YOur previous LTE device is fine).Or go to the store and ask them to activate and LTE sim for you.
wobblefix
