A Volume key symbol popup appears in my phone
  • Start date Start date
A
AC Question
Recently an infected app got installed in my phone accidentally. I later uninstalled it but after that after regular intervals even in idle screen this while volume symbol appears into the center from the bottom of screen with a blip sound & then goes down again. I have scanned my phone with most Anti Virus softwares &found nothing but it's annoying appearing in between videos or gaming or anything freezing the screen for a second & then disappearing. I can't make it stop. Anybody face such a thing??
Hello .. This happens due to freaky sim cards.. Just go to sim toolkit and deactivate alerts... If you can't find toolkit go to sim card manager and find there.. Search all the tabs in sim card manager for toolkit..
Sim toolkit stop service and booyah
hii rahul.... i am srilekha .. evn i also use d same phone lenovo vibe k5 note nd i'm also fcing d same volume pop-up problem like u. i juz want to know whether u r solved wid dat and if so hw?
Just go to sim toolkit and stop airtel now services or any other operator also stop thier respective services
Just go to apps and find an app showing your operator name in that app you will find sim tool kit. In notification you have to disable everything.
That's it. The icon will disappear now....
Good luck
HourFromNow
