A whole bunch of apps for $0.10
I think I am not understanding the question...
They are widgets, they do not replace your homescreen. They are elements added to your current screen, you can easily remove them by hard-pressing on them, and dragging them to remove.
Is that what you are asking? Or am I misinterpreting?
yes. sort of. I've never used anything other than the stock widgets and it wasn't clear how to go back to the stock settings if I do not like a widget I've changed on my homescreen for example.
It doesn't do anything to your stock widgets. It just adds more widgets to choose from, if you get sick of a widget, remove it from the home screen and put the stock on back.
All your stock widgets are still on your phone.
Reactions: obidos
Today's Specials
Pano is sweet I bought it on sale a while back. It works great and defiantly worth $0.10
I was looking at that. I don't usually take many pictures but the app sounds cool and $.10 is an awesome price.
Edit: I just downloaded the app and its definitely worth $.10!
SebastianJack
