AC Sideload Wonder Machine for Windows
Status
Not open for further replies.
Sideloader for Windows on Samsung Captivate At&T
Hi:
I got the app for Windows and it installs fine under Windows 7 64 bit, the only problem is that I still get the message that says Apps not sourced in the Android Market are blocked. My phone carrier is AT&T. How can I get around this ?
I got the correct driver but I cannot get around this restriction.
Thanks,
Does the sideload wonder work on Sony Ericsson Xperia (X10). I've tried everything, but the loader.bat can't see my device. My driver said "Sony Ericsson sa0101 ADB Interface Driver". Is this the correct type of driver to use. I've look on the Sony Website to find another driver but i haven't seen one. Any assistance will be greatly appreciated.
USB cable plugged in. Debugger turned on. Not mounted.
Worked Perfectly!
Used the Sideload Wonder to install Tether on my HTC Aria. Have a Windows 7 Pro laptop, so .NET was already there. Just followed the simple instructions, installed that .APK file, and BAM! works like a charm. Will be cancelling my USB Wireless Broadband plan from AT&T costing $60/month. THANK YOU!!!
I keep getting an insufficient memory message, Im using a Moto Backflip, any suggestions?
Ps: I dont even have that many apps on my phone.
Hello,
I have Windows Vista and my phone is a Motorola Backflip MB300.
I have unzipped the files (AC-SWM) on the Local Drive C:/
I have installed both Microsoft.NET 4 and my respective USB Driver.
But once I try to open the program it says I'm missing the .NET program, does anyone know what the problem is, I confirmed that I installed the program.
HTC Inspire 4g
I am unable to find usb drivers for the Inspire and the device is not recognized. HTC's site only had the sense software for the inspire as far as I could see. Any one got any suggestions?
Hello. I just wanted to say thanks for your app. I have a Samsung Fascinate but no web access so I was looking for an easy way to get a file manager on my phone to allow me to then install apps from my sd card.
I'm not sure if this was supposed to happen but the first time I connected my phone it was set up as a usb device and modem (both of which post 16 says not to do) so when I tested the usb connection my phone was not recognized. The test caused windows to re-recognize my phone as a hardware device though so when I ran the usb connection test again my phone was now listed.
Whatever works I guess!
Edited to add: I think I made this process way more difficult than it needed to be. I didn't realize I could use the MyFiles app already on my phone to install apps from my sd card. *rolls eyes* Can't learn without making mistakes and boy do I make them.
i try and install the apk and i get the error message saying
'loader.bat' is not recognized as an internal or external command, operable program or batch file.
how do you fix this?
any suggestions?
Q: do I navigate to apk file in my pc or do I put it on phone and install from there? Also seems in the dos box I get message: Device could not be found. I have the HTC Inpire. Can I get help on this please.
Application Error
I did everything like it says but i aways get this error when i try to run SWM, The application failed to initialize properly. What should i do? Im using a captivate by the way
It says error:device not found i followed all the steps and set up the adb and on computer > manage it shows my adb driver installed on my phone so what did i do wrong?
It says the driver is working properly but on the sideloader it says device not connected so that means i downloaded the wrong driver right?
HTC Aria
When I tried to install Sideload Wonder Machine on my phone I still can not get past the security placed by AT&T. I can download a file to my phone but can not install or run the program. Can anyone help with this? The instructions I got where to go to Applications and and allow third-party software, but I do not have that option. So I have an HTC Aria that I can not really use. HELP.
I am trying to reinstall my deleted stock Music.apk on my Motorola Atrix. I get the error "Failure [INSTALL_FAIL_DEXOPT]". Both diagnostic utilities are running without error.
Status
rvrsco
