AC Sideload Wonder Machine for Windows
Status
Not open for further replies.
used successfully on my non-rooted atrix. no hickups. thanks for the great tool
This definitely works to download the Amazon Appstore on my Atrix 46 with AT&T, however, I am unable to install the apps I download from the Appstore. I still get the error message saying that due to security..... I have been searching for a way to install the app directly to my computer so that I can use this program to get it on my phone, but I have been unsuccessful. Any help would be awesome!!
Just plug the phone into the computer and use as a disk drive. From the computer search the phone for ".apk" that should list all the apk files on the phone. Move those to the computer.
Amazon market apps have funny names that you can't determine what it is. I am going to try to rename an apk file and try to sideload it. Might work or might not.
Then unplug phone from computer, then plug phone into computer and use "charge only" setting. Then use the sideloading wonder machine to install the app.
Bryan
Reactions: WarrenH
You are
welcome.
I did rename todays free poker app and it did load the program. However be aware that the app will need to download a huge file in order to work and that file is around 250megs.
Bryan
Worked for me on an AT&T HTC inspire.
I did have to install the HTC Inspire Sync crap to make it work due to their USB drivers being proprietary. Just make Sure you close the app and kill it from the system tray before you run this or it fails.
Reactions: ilmostro11
It worked for me when the HTC sync app was up, there was a "failure" message, but it still worked. Something about the adb server was out of date.
So I closed out the HTC sync on the puter and the failure message is gone so thanks for the tip!
That free app from amazon market today sucks, don't waste your time dl a 250meg file!
Bryan
where can i find a usb driver for an inspire from att?
Just google "htc sync" and it will give a link to the file at htc.com
It should have installed the usb drivers when you plugged in the phone for the first time however.
Bryan
Well I used the large 250meg "world series of poker" files I downloaded into my phone and used those same files on another phone and it worked so I didn't have to dl it again. Still don't like the app but now I know I don't have to dl large files to each phone separately.
Bryan
Once you install the .APK file through Sideload Wonder Machine I assume you can then delete the .APK from your phones cache, right? What about the directory?
i.e.
Directory of E:\Android\data\com.amazon.venezia\cache
03/22/2011 07:18 PM <DIR> .
03/22/2011 07:18 PM <DIR> ..
03/22/2011 07:19 PM 13,055,119 vnz47846.apk
other than it taking forever and a day to download the HTC Sync package from HTC's website, this worked flawlessly.
Wanted to add my thanks for this app and all the helpful comments in the thread got it to work on my Captivate
Android Central Sideload Wonder Machine v. 1.1
Installing application
1561 KB/s (6846655 bytes in 4.281s)
pkg: /data/local/tmp/to_install.apk
Failure [INSTALL_FAILED_DEXOPT]
If you do not see an error, everything was
successful and your application is installed.
After exiting the program, you may unplug
your Android phone.
Press any key to continue . . .
Is there a way to sideload system app?
I loaded as directed and it says already installed but I can't find it anywhere?
1317 KB/s (1346987 bytes in 0.998s)
Failure [INSTALL_FAILED_ALREADY_EXISTS]
Status
dumpsterrentals104
