AC Sideload Wonder Machine for Windows
Status
Not open for further replies.
OK new to this how do i get a apk file i have none on my laptop..Can someone list one or? Hmmm...
Not sure..
I'm not sure what I'm doing wrong. I have the USB driver installed for my phone, the Motorola icon is in my task bar by the time. There is no option to choose debugging mode. There is an option for when it connects to "do nothing". I chose that.
ASWM ran fine it seems but the diagnostic tools did not show my device listed and there was no serial number listed. Not sure how to proceed. Any ideas?
menu>settings>applications>development>usb debugging
leave it set to do nothing when connected, and give it a whirl.
I have a Captivate and am wondering how i uninstall apps I have sideloaded (i used the SWM if that matters)?
Great piece of software although i was only able to use the first beta not the updated one, it wouldn't see my phone but the first was able to.
I downloaded the zip file and when I double click it it says "this zip file is invalid" . Its also only 64 kb. I've tried to download it a couple times and it keeps saying the same thing. I have no internet right now so I downloaded it onto my phone and moved it to my netbook. Could this be why its not working? I've downloaded other things like this before and its always worked. Help?
Ok so trying to side load an app on my Captivate, keeps showing the device as offline, lists the serial, but says offline, not sure what to do.
It passes all the dignostic tests then when i go to install it i get this message @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
Android Central Sideload Wonder Machine v. 1.1
Installing application
964 KB/s (0 bytes in 77197.000s)
pkg: C:\AC_SWM\payload\Swype-Installer.apk
Failure [INSTALL_FAILED_INSUFFICIENT_STORAGE]
If you do not see an error, everything was
successful and your application is installed.
After exiting the program, you may unplug
your Android phone.
Press any key to continue . . .
Any Ideas? I have 1.5gb's free on my phone.
Easy way -- install an app uninstaller from the market
Less easy, but doesn't require an extra app -- menu>settings>applications>manage applications. Find the app in the list, press to open it and choose uninstall.
Sounds like it won't download via the phone. Not sure why, but you see that a lot from forums. Drop me a line via email and I can mail it to you, maybe that will get it on your SD card for copying to the PC
How do you get a dang payload folder.
Not sure why some people aren't seeing one, cause it's in there. Maybe because it's an empty folder. In any case, juts make one inside the AC_SWM folder, and name it payload -- leave it empty.
USB driver needs installed. Hit the Captivate forums for more info.
your Android phone.
I hate that. Really hate it.
I can't duplicate it here, and it doesn't happen to most people, but it's something screwey with the Captivate. I have no "official fix", but read through this thread to see some unofficial fixes that seem to have worked.
I am getting the same out of space error trying to install Firefox. I have over 10gb free on the phone and 13gb on my memory card. Samsung Captivate. I am so sick of this phone
i have a sony ericsson xperia x10...i have the usb debugging connected...but my phone is not listed under the list of devices attached when i run the program... what did i do wrong?
I download the zip file but it comes up an efw file. what is this is how can i get this program. im frustrated and been at it all day. Please help
You need to download, install, and set-up the Xperia Windows USB drivers correctly. Sorry, but I'm not familiar with the new version SE released.
The download link works fine here. I'll bet your anti-virus scanner renamed it.
for me it says [install_failed_older_sdk]
trying to install launcher pro. what is goin onnnnn ?
Install_failed_older_sdk means the app you're trying to load needs a higher version of Android than what you're running.
Status
BNIDIRECTt
