[ACS][ROM] Phoenix ROM 0.2 & EXT Data
Re: [ACS][ROM] PhoeniX ROM 0.2
Can you share how you Installed Like2SD and set ext4 one startup and rebooted.
I'm somewhat familiar with linux, but I haven't set the ext4 on this phone yet.
Thanks!
Thanks!
Yea man. I'm just now getting up and around so give me a bit and ill type something up.
Edit: Posted a little how to in the section. If theres any questions, just reply there and I'll try to help.
Pretty cool. If we can get system apps to move then we'de be good. Lol
It's been said quite a few times in other threads, but I'll repeat it here, and put it in bold to catch attention for a lot of the people who scroll through really fast and claim they couldn't find things. ;)
APPS IN /SYSTEM DO NOT AFFECT FREE SPACE. The entire point of removing apps from /system/app is to remove things you'd never use otherwise from your app launchers.
Once again, it DOES NOT affect free space. Here is the most simple explanation I can make:
/system, /data and /cache are different partitions. For those who don't know what a partition is, you can think of it this way (though, to be clear, this is NOT what they are, just a way to get a simple understanding!): Think of a hard drive in your computer. Let's say you have 2. One for Windows like most of you probably use, and one where you install apps. Let's say Windows is drive "C:" and you tell all your programs to install on drive "E:"
If you run out of space on E:, would removing system files on C: really affect space on E:? NO.
Even more simply put, /system, /data and /cache all have separate storage space.
I don't mean to sound angry, rude, or calling anyone stupid here, don't get me wrong. But I keep seeing the same thing over and over, I just wanna clear things up. It's also why I'm working on sd-ext for you guys which partitions your sdcard to use as /data (where your apps are installed).
Thats whats in my data/app
sitting with 119 megs free.
system/app
http://pastebin.com/Byce0bzz
Reactions: randyist
So people can see what is actually on my phone even tho I have 119megs free...lol
Link2sd is really good for these phones.
If you're enjoying that, you're going to love when sd-ext is posted. No tricks for tricking your system and more than the default amount of space. I installed facebook and g+ as a test and my data soared up to 200MB+ after a little bit of web and social network browsing. You won't need to bother clearing out data anymore if you have decent sd cards.
Reactions: randyist
I'm just using the stock sd card that came with the replenish. Can't find class 6 8 gig. The only issue I have is in link2sd, under second partition, its only 120megs. If I was to do a fresh flash of gb, when I format my sd for a bigger ext partition, I should be able to change it right??
Any eta on when ext2sd will be posted?
Edit: is there a way to change the lockscreen?
For those of you wondering about the sprint update to the replenish, samsung has released the open source to the kernel. I will use that release to release a modified kernel, so we will get the security update at that point. So no need to do the update if you don't want to.
That being said - has anyone out there gotten and run the update. If so, I need to know the contents of build.prop. Is someone willing to get that to me. I can let you know how if you don't.
Yes, you choose the partition sizes. You just need to be able to do basic subtraction :P No eta, I can't currently test and still don't know why I fail every other boot.
Look for apps, some have the ability to change it. I like songbird for my media player and the lock screen transforms into a media player instead.
Quick question. Does someone have the png for the ICS dock? I'm adding all the ICS elements I can and can't find the dock. Uve added the dock icons but can't find the dock.
Ill check songbird out. Thanks.
Update:
No errors since install. Moved the biggest apps I have by sorting by size of all. Here's a screen shot as well. Quick question, what's the difference between linking the files and just moving them? I linked em first but still had to move em back to SD. And if I linked em after I moved em to SD I would have to re move em. Normal?
Moved:
Facebook
Dolphin Browser
Cut The Rope
Also moved 10 more smaller apps, but in all I've saved around 45megs. Went up to 90 free. Pretty cool. If we can get system apps to move then we'de be good. Lol
Click to view quoted image
Will post back with updates and full list of all apps/locations
Edit: Got some more free space. Uninstalled some system apps with Titanium and linked some more from my internal storage.
I'm not 100% sure on the difference between Moving and Linking. I just know that you Do Not want to remove that SD card after doing any of thise - as obvious as it sounds - because it will mess up all of your shortcuts to any of the apps that were moved with this app.
I noticed that you said you used Titanium Backup to uninstall apps. Have you tried Uninstalling any apps with Link2SD ? It does that well enough for me, that i uninstalled Titanium Backup and saved myself the 3 megs or so.
You totally kick @##. this will be awesome!
I just purchased an Micro SD Card off Buy.com from earlier this week (8 GB for like 5 or 6 dollars) .. it's a Class 4, so i'm scraping by there, but should still be fast enough.
Buy.com has some pretty ridiculously well-priced SD memory prices.
How do I pull system apps from the rom image itself??
Want to make a base of just the stuff I use. I pull alot of apps out with Titanium when I first flash it and id like to just pull em out before hand and when I reflash, I'lll have the cleaned version...lol
adb pull /system/app/appname.apk/odex /path/to/destination/appname.apk/odex
You already did it when you posted earlier, ls /system/app/*
I can't believe I didn't realize I only had one primary partition on my new micro sd card. hah, i need to learn how to sleep at night. I just added a partition to my micro sd card using Gparted in Ubuntu and it works well.
Now I'm going to try Link2SD to its full potential.
So I'm new to this hole rooting thing I've got My replenish rooted .. So different ROMs have to be comparable with my phone? So after rooting with Phoenix 0.2 Are there different Looks ?? Gingerbread?? I'm not sure the difference if there is one ... Can someone xplane and if there are Different Loos versions and what the difference is?????
I'm redoing my phone. Now. Installed Status Bar Settings and it wouldnt let it load..just force close something(don't know what) and the phone would just reboot...crap.
Ok..Got it running again and the update popped up.
Went to /cache and it was there so I'm posting it for all of ya'll..lol
It's 14.7 megs and I'm uploading it to my dropbox now.
http://dl.dropbox.com/u/10851246/67ffcb5cbd91.update_SPH-M580_EK18_to_FA19.zip
Reactions: juneonthewest
kankuraon
