ADW launcher EX
Vick, I still haven't tried it yet. What is it that you didn't like about it and why? Thank you :)
I'm about to uninstall this. I don't see myself using this over golauncher
I was in the same boat as you. Once I downloaded Go Launcher though, I never looked back. ADW does have a lot of themes but GL has more customization with screen transitions (as well as themes).
GL is just much more intuitive, smooth and has a ton of customisations and options. It feels more like a stock UI and not as much a launcher, plus i'm used to and invested in it. I just couldn't get into ADW, maybe because it was too complicated, or maybe becuase GL just did everything better and i just didn
t have the patience to learn it.
Reactions: CarrieK
this may be a silly question but is it easy to revert back to stock settings from the ADW customizations?
The way I do it is by pressing the home key...it will ask you if you want to use sense or adw. If you have checked the "use this as default" just to to the application under settings and clear defaults.
Sent from my PG86100 using Tapatalk
Beeboos
