And my case addiction has started.... lol
The ESR with kickstand case looks interesting. Which case model do you have, with or with-out the screen protector?
Here is my ESR case charging the Galaxy Buds. and yes I have the screen protector that came with the phone.
Great, thanks for the info. Was it easy to apply the supplied screen protector? Do you like the screen protector? Does the finger print scanner work well with it on?
You're welcome. The screen protector came pre-installed. I don't know if I could make it look this perfect if I tried to install myself Ha ha ha! The FPS is okay but still far from perfect. It is better than the S10+(if you had that phone) but nowhere near how fast the Pixel 3 XL is.
I am enjoying my Samsung rugged case in Black.. Couldn't help myself and wound up purchasing the Samsung led wallet case. It was between that one and the s-view. Got a deal on the led case for $44 on Amazon. Couldn't figure out why it was that cheap but went on and got it. Have never had the led case or s-view and I have had the note phones since the Note 2. Looking forward to it. BUT you can't go wedding with the Samsung rugged case as well.
I need to stop buying cases. Seriously, what will I do with all of them?
So just over a week and I'm up to 7 cases for my Note 10 plus 😀 My girlfriend has the regular 10 and is up to 3 lol
Samsung silicon case (not pictured)
Otterbox
Knock off otterbox bc I like green and gray
Speck clear case
S-view case
Poetic case
Ringke case
Waiting on the lifeproof case in blue to come to my local best buy... and then ebay and Amazon for different color cheap cases.
I'm doing my best not to go crazy again with the cases. I had 11 for the N9. I've got 2 now the Defender which I moved away from all OB cases but now the Defender is a great feeling case and protection is top notch. When not at work I will use the Supcase
Otterbox
Speck clear case
S-view case
Poetic case
Ringke case
Let me know about LifeProof. I didn't think they were making cases for the Note...here I go again
What did you not like about OB? I bought the clear symmetry today because that's what best buy had when I purchased my phone. It is slim and crystal clear. Not worth $50 but I want going back to work without a case on my brand new note.
The commuter had soft rubbery sides that would pull away from the phone. The Defender now has much harder plastic that keep tight to the phone
So far I'm on par with my case addiction. I have 3 clear back cases. Even though I have the Note10+ in black, I also have developed a thing for skins, so I need clear cases with good protection. And ever since I moved to Samsung's curved display devices, I have been rightfully paranoid about protecting the screen, so I've been using the Whitestone Dome screen protector since I discovered it for the Note8, and it did it's job on more than 3 occasions. So the case also has to be compatible with it.
I started with the Caseology Skyfall, because that was ultimately the case I used for the better part of the 2 years I had my Note8.
I ended up also getting the Supcase with the clear back, because that was the second case I purchased for my Note8, but that one had a frosted back cover, and it was just before I found all the skins I liked.
And the very first case I had for my Note8 was the Ringke smoke, it was very good, up until it dropped and pushed my WSD corners up. the screen protector still did it's job, but the case just wasn't very compatible with it after the first drop.
All that to say, that for my Note10+, I have the Caseology Skyfall, the Supcase, and the I-Blasion for the Note10+. The I-Blasion is probably one of my favorite case designs, ever since I had the Supcase Unicorn Beetle Pro case on my Note7/S7E. I would have gotten the Supcase Unicorn Beetle Pro case, but I need the clear back, lol.
Ghostek Covert, Spigen liquid armor, and one of the Samsung cases with the dual kickstand for me so far. All good cases but I like them in order that I have them listed. Ghostek because it's the only one with a clear back. If you want a slim grippy case that Spigen is excellent. No reason for me to buy another case but of course I will.
I got the S-View Flip Cover, Samsung silicone cover, ESR with metal kickstand and 2 off brands from Liwarace and SQM
Do you have any problems with White stone screen protector coming off as you change cases. I had to pull it off after taking off the Defender and putting on my UB pro case.
No, I don't. I switch between the Caseology Skyfall and the Supcase Unicorn Beetle Style depending on if I'm going to work or staying home. The Skyfall is a tad bit thicker and more edge grip where the Style feels more slim in the hand and feels like it has less of an overall footprint.
The only case I am hesitant to use is the I-Blasion Ares case, which is similar to the Supcase Unicorn Beetle Pro case, because the frame sits almost flush with the Whitestone Dome. I've seen reviews where the combo was dropped and the screen protector would be pushed up.
uOttawaGrad_22
