Android 11 public beta now available!!
Yeah same here downloaded the iOS developer beta 3 and Android 11 beta 2.5 on the same day. Living life on the edge
Anyway mostly stuck at home so reliability isn't that much of priority as if now
They are actually both pretty stable ....gotta live on the edge ..
With the new 5.5 MB s/w patch, It seems as though opening the camera and moving to portrait mode is smoother and faster now.
Yeah, I hear you dude!
I switched to Spotify for now anyway as it works. I'm liking it so far, might keep it. Was using Pandora as my alarm in the morning and was bummed it didn't work any more. Spotify works as alarm also so I'm good to go. :)
Uninstall and reinstall Pandora. Should work again.
Thanks for the tip but that was one of the first things I tried, “twice” and a no go. Still just crashes when I try to open.
Weird, that's the only thing that helped. They were quick to respond to my email though, so try telling them your experience.
I had the same issue. Uninstalling/re-installing didn't fix it. Then I cleared out all the data after one more re-install. Both cache and user data. Rebooted, and Pandora works again.
I just started noticing that tapping on the temp on the pixel launcher no longer brings up the weather frog it brings up the Google app. Anyone else notice this? I kinda want the weather frog back.
I've still got froggy. He was in hiding yesterday with the hurricane passing by.
Ashok Dharshan
