Android 12 Beta 3 out. Features and Bugs.
  • Thread starter Thread starter Deleted member 2609113
  • Start date Start date
It took an hour, but all is ok now. Thanks for your help and other responders.
That's great. One consolation is you can still use the phone for however long it takes to update and install.
If it worked like it was intended it wouldn't be as bad , but from what I seen it's been slow on certain things , maybe they have better handle on it now
Frustratingly it just might be working as intended.
So, I just sent Google some app review from the Play store under Gboard beta. Check it out...
Hello, would it be possible for a gboard beta material you auto theming to be more pronounced with the color theming? Especially, for the green colors... Check out my attached screenshot.
With beta 3.1 update, I noticed two things with the screenshot feature: one, the screenshot if you don't interact with it, auto dismisses itself out with a dice. Number two, if there's nothing to expand the screenshot with, you don't have the option. It got a bit smoother.
Anyone else having delayed notifications from apps? Specifically, Tapatalk? I'm literally getting alerts 8-12 hours after a post or response.
No, unfortunately. Sorry to hear that you're having an issue. Send it to beta feedback general app issues though. Or OS issues. I also don't have a talk app on my phone anymore. It was a battery drain via Google Play services unfortunately :-(
I'm getting delayed notification on Tapatalk, even on my Samsung Note20u about 3 hours delayed
Another example how some models can have issues while a different model of the same brand doesn't. It is very frustrating and hard to pin down.
I realized I have adaptive battery save that's why my notification were delayed , it kicks on at certain times.
But it was like that before the beta right? I didn't make any changes to that ever and since latest beta my Tapatalk has been severely delayed. I don't even get notifications for this thread anymore except for email. And yes I'm still subscribed for notifications in the app.
This was on my Note 20u no beta on that
Ninja01
