Android 12 Beta 3 out. Features and Bugs.
  • Thread starter Thread starter Deleted member 2609113
  • Start date Start date
That for instance, the gboard update, would be different on different pixels.
Would it? I don't see why. But that would be a good reason why the phone being referenced to should be in the post because an issue might be unique to that model of phone.
Like I wrote some pixels have different camera capabilities (multiple lenses for example) then others, or different processors.
The phone model helps in trouble shooting as well.
For reference, I have a Pixel 4a.
It makes sense that camera capabilities might be different with different models due to specific hardware. Some capabilities but not all.
Why aren’t some people getting the gboard update though? There is no hardware difference for the keyboard, is there?
I haven't received the Gboard update on my Pixel 4a either. Not too worried about that particular one.
Some app updates like Gboard might not reach everyone in one time frame same as dark mode is google server side that doesn't hit everyone apps at once , but say pixel camera app update could vary for different models
4a here and no gboard update yet either. As stated above these rollouts are server side and like the dark mode rollouts for like gmail and calendar they came out gradually as well, also server side. I don’t think google has any prioritization for any particular devices. One day you’ll notice it’s arrived.
Noticed a small 738kb update for my Pixel 4XL this evening. It's SPB3. 210618.016. I proceeded to install it, but it hangs about one third through optimizing apps. I tried rebooting and resuming the install and it hangs again while optimizing apps. Any ideas how I can force it to finish the install? I've installed 3 Android 12 betas so far with no problem.
It will take anywhere between 45 minutes to over an hour. There are several posts above about how long it took. Just let it go on doing its thing. It does take a unusually long time.
Can try setting>apps>system apps>tap software and scroll to storage clear it's data and force stop it
It took an hour, but all is ok now. Thanks for your help and other responders.
So it sounds like "server side" isnt the best way to roll these things out. Is that correct?
So it sounds like "server side" isnt the best way to roll these things out. Is that correct?[/QUOTE
it is a good way. In some cases it's the only way to roll out updates that require server side functionality, when not all computiting done at the client (phone) level. Server side updates roll out slowly so the applicable servers don't get bogged down with every user receiving updates at once.
If it worked like it was intended it wouldn't be as bad , but from what I seen it's been slow on certain things , maybe they have better handle on it now
BNIDIRECTt
