Android 12 beta now available.
Status
Not open for further replies.
The new Play Store layout is way more complicated than it needs to be, in my humble opinion. Just my 2 cents.
It's still there. You have to tap on pic/av.
Looks like I'm late to the party.
Its ok , thanks also.
Also, I figured out why my status bar keeps disappearing. When I use YT Music (which is always in the Jeep) connected to a Bluetooth device the status bar disappears. When I completely close YT Music completely (swipe away from recent apps) the status bar comes back, most of the time. A few times it didn't until I did d reboot. I'm not sure if this is intended behavior, as part of the "new mini media player" functionality, but I'm not crazy about it. I'm gonna submit a bug report and see what happens.
Yeah submit one see if they respond normal behavior
The only thing I liked was that I was able to select my apps by checkmark when I did a clean reset and install. It was easier than constantly being taken to the top of the list once i installed an app
Actually the three bugs that I've reported have not been fixed in this release. Two of those bugs I've reported for each of the previous Betas.
Assistant will not turn on DND but will turn it off. I have several routines that include turning it on. So it's a bit frustrating.
I have had mine set to automatically turn off when my alarm goes off in the morning or it hits 7:30. Both of them have been working through the beta. Never tried using assistant to turn it on or off.
Assistant was working just fine on Android 11. I use it a lot during the day. Every other routine and instructions seem to work great.
Just to be clear. Assistant turns DND off just fine, but not on.
Status
araelbenjie
