Android 4.1.2 OTA Update Now Rolling Out to Nexus 7 - Adds Landscape Mode
Just did the clear data method trying to force the update and I got it. Had to do it 3 or 4 times. Updated and still have my root. :D Now all I need is JB on my GS3 and I'll be a happy nerd
Probably a coincidence but I did it 17 times and finally got the update.
Mine's here. SoCal. My mom took it to work, and when she came home it was on there already. She said she didn't even touch it, her friend did though.
Huzzah! Clearing the data didn't work nor did restarting it but turning airplane mode on then off did the trick!
Sent from my HTC One X using Android Central Forums
I just wiped data and got the update after one try.
Sent from my SPH-D710 using Android Central Forums, thanks Android Central.
Don't bother, that doesn't do anything. I cleared it 10 times and restarted too and still no update. It has nothing to do with whether you get the update.
It certainly did do something in my case. There was less than one minute between "Your system is current," clearing the cache, and 4.1.2 ready for download and install. The odds of me just happening to clear the cache just when Google makes 4.1.2 ready are pretty slim.
Good luck with the screen lift! Hope it works out for you, I've been lucky to not experience that as of yet and I've had mine for a while now. Guess I don't us it as much though as I'm test driving a fruit product!
So I just fixed the screen lift. Took out the screw where it was lifting put it back in and boom its gone. I'm a happy camper.
Well tried clearing framework data and no success!
Might try a reset but really don't want to go through setting everything back up.
Try turning it off after clearing data
Clear framework. Turn airplane mode on and off, check for updates.
Well looks like the airplane mode trick worked! Now let's see if the performance will stay consistent!
Still no update for me. I've tried everything except clearing framework and resetting the unit. I've got a C80 unit in the DC area. Waiting patiently.
yeah just wait patiently... its still Jb and have some performance improvement and very minor feature.
let it come to you.
pulatgu6
